Hi guys,
I'm due for a front brake pad replacement per the OBC. I've been confirmed by AB that the 5 years BSRI does not cover brake pad replacement. This is what was quoted by AB:
Front brake pads - RM 934.20
Sensors - RM 175.42
Include GST for both - RM 1109.60
Labour cost - TBConfirmed
Can you guys shed some light to me on what is the best option:
Is it worth doing it in AB or i can replace the brake pad at a specialist?
Would this void my BSRI?
Once the brake pads are changed, would it be able to be reset if i do i outside at a specialist?
Is it a must to change the sensor each time i replace the brake pads?
Help pls.....
Sensors - RM 175.42
Help pls.....
