i have experiencing misfiring problem for abt 3 months now...just found out kahar has the same problem with me...did a search in e46fanatics.com..still i cannot get a clear answer to my problem.i have misfiring in cylinder 1 n 5..i have awap the coil but still the problem persists...i have change the air mass sensor...cam sensor...coil..but still i do not know what is the problem.during morning when i start my car when the temperature is cold my car will start to shake however the rpm meter did not goes up n down...then the fault light which look like a box with a t on top will light up...then i restart the car again..once the temperature needle reach to the middle then the car is running fine...any e46 owners out there are having the same problem like me?should i update my dme?change the vanos?please help....i could not send my car to AB cos my car is a grey import...anyone has the same problem pleaz post it up here thanx!!
