engin oil check light
mikeraj04
Dear sifu's,need some advice, yesterday while im driving i notice the engin oil check light is on then, once reach home, after the engin cool down this morning when i check the engin oil the level is ok......this happen when im speeding at 150 or long distance ride..............pls advice me......:wink:
Engine oil level sensor not sending right info to OBC. Can be wiring, can be the sensor, can be your oil got problem.. item 2:
thanks astroboy,
yes you are right here, my engin oil sensor got problem i change it and the problem sloved
mikeraj04;743327 said:
thanks astroboy,
Bro Mikeraj04, mind sharing how much it cost? N how did you confirm problem solved after changing it?
i've been having the same problem on n off too, especially during aggressive driving..in the morning it will be all fine..
i've been told my car needs a top-haul..hmmm...
Hai Bro,
sorry for the late reply, the cost is 350 for the sensor, the mech told me 2 things to check if after changing the sensor still the same problem then of course need to overhaul...bro....pls keep yr fingers cross.....mine is ok now......
Hi Mike, how did your mexh diagnosed the problem as due to te sensor instead of something else?
he check my engine oil level and its ok, so he change the sensor then its fine till now...bro,
