valkryie
- Nov 19, 2005
- 267
Hi All, Can the tire shop repair a punctured tire that was filled with emergency tire sealant such as those conti kits or BMW M mobility kit? Some articles mentioned that the tires be replaced after the emergency fix. While there was one article that mentioned about needing proper equipment, disposal facilities and training to remove the tire and drained the sealant off. The article just mentioned about removing the sealant but it did not expressively mention that the tires can be repaired/patched. But why take the trouble to drain out the sealant if it is not to repair the tires? Maybe you need specialised training to remove tires filled with sealant in preparation to replace the tires.
