JCKL
- Dec 4, 2004
- 757
David Yong;459535 said:Hmmm.... it is a sign of it's time to let her go alreadyHahaha...
Hmmm..........I wish I can afford a 335i like you!:63:
oligokoko;460158 said:Possible faultts on e90 325i engine vibrate :
1. engine oil sludge
2. ignition coil
3. air leak
4. dirty fuel injector
5. defect spark plugs
these r sum of d easy/usual culprits. let d IA guys take their time 2 check on this.
bmFIVE;460369 said:IA had checked Item 1,2,3 & 5, but problem persists.
I suspect now it's fuel/fuel system related : I've used V-Power from day1 of owning the car and when Ron 95 was introduced, I switch to ron 97 due to scarcity of V-Power. The vibration problem started few months later. I pumped a tankful of V-Power last week & the vibration became less pronounce & less frequent. I'll continue to use V-Power from now & see if the problem could be eradicated.
E46Fanatic;460769 said:My analysis of this thread so far and based on past postings, is Oligokoko is surely a technician at one of our authorized BMW svc centers. Korek or not?![]()
oligokoko;460617 said:might be d DME adaptation value then. DME always try 2 adapt with d driver's driving profile. if all this while u r using Vpower n then recently change to ron97 n d prob starts, then it might be it. clearing the adaptation value might solve d problem. just my 2cents.
mind sharing your UDM's mileage? is d vibration only happen when idling or even while driving?
bmFIVE;460772 said:My car's mileage is 47k km. It's registered Dec 2006.
Vibration is noticeable during idling, There's no loss of power while driving.
E46Fanatic;460773 said:Is it idling way to low kicking in the anti stall program? Does it get worse with A/C off?
Spaceman;461012 said:hopefully nothing major, otherwise any 1 of us might be the next victim ..
is yours a 2006 325i CBU?
