E60 Voice command problem
C
ckng2000
Guest
Hi all! I need some advice on my E60. Hope all the sifus here can help me. I managed to link my phone (Sony Ericsson W810i) with the bluetooth comminication system in the car and everyting works fine, i can even sync the whole phonebook over. But the problem is, i see all my phonebook contacts in the idrive screen but when i try to use the voice command "Phonebook", it says my phonebook is empty. Anyone can advice? Also my car cd player doesn't support mp3 music, if i upgrade the firmware of the idrive system or if i add i cd changer, will it be possible to play mp3?
did u opt for the voice command function in the first place? If you do then cannot help u la brother.. if you don't, then that would be the problem laaaa.. :D
I've checked the manual and it actually say specifically not to use the phone directly once it has been connected to iDrive.. It might go hay-wire!!
