The rear suspension has 2 upper track arms ie. the front one(straight and shorter) and the rear one(bengkok and longer).
The front one the ball joint koyak ady and the ball was really loose in it's socket
gotta mark the eccentric bolt or otherwise must do alignment
plan view of the eccentric bolt (to adjust toe)
where the eccentric bolt reside
my symptom was twitchy arse and the rear feels loose at speed > 120km/h
and when I rock the wheel at 3 n 9 o'clock position there is movement
hope this fixes it as I have yet to test drive to see the result.freakin expensive for a stupid fragile looking arm as opposed to the front suspension thrust arm....
