e60 - power window problem
zackme07
Hi guys,My e60 window just went down automatically on driver and side passenger. For some reason, it cannot be up and the window button did not work. I have replaced the fuse but still no joy. Can anyone suggest what can I do to fix it or recommend a good bmw garage around klang valley?Many thanks.
Did you check if there's any error codes? Could it be the button that's not working?
zackme07;748199 said:
There was an error - Anti-Trap disabled on Idrive.
That's a good clue. Normally if there's an error message, there would be recommended solution(s) on how to fix the problem. Although in some cases, the solution might be quite vague. Did you try going to a BMW specialist to see what is their opinion?
Bro, just go to any BMW authorised outlet (AB, Ingress, Quill) and hv them do a resetting on the ecu. Happened to me once and now back to normal since. Lucky no major issue unlike my rear passenger side where the whole motors and wires got tangled up and damaged.
:listen: btw, dont try to force closed by pressing the remote button continously. That will definitly damaged the motor.
zackme07;748064 said:
Hi guys,
Many thanks.
Sorry I forgot to update about this problem. I went to German Mechanic in Desa Melawati to ask them to have a look. Guess what ? The problem just sorted in two minutes.
According to the mechanic, the window/remote needs resetting for some reason. He just pressed and hold the button from the remote for 5 sec to reset and operate the window.
But why some cars , when u press the remote for a long time, the window doesnt go up and down ? is it some setting or the feauture not included in the package . I tried mine , japan spec 2004.. nothing happen .
So far all ive seen can open/close windows with (hold few sec) remote press. However that feature can be coded to ur car by a bmw coder/programmer
