E46 electronics or IBUS and KBUS when crazy!! HELP!!!
anaksarawak
Official Member
Ever since I have my car fender and bumper repaired I experiencing electronics grimlings.It staggered with airbag and rollover warning light, follow with rear red light, cluster dim, no fog light indicator no highlight...., Quickly I GOOGLE and follow an instruction to reset the cluster via hidden function 21 and boom! Cluster light is bright now, rollover light and airbag are gone but the radio turned off, steering light is off and lost funtionalibility. I turn the radio back on and transmission error light pop up too! I have tried disconnect the battery for hours Checked all fuses and relays Brake switchSteering connectionPlan to remove the radio today.Lots of research, check my car's showroom thread x69 Most of my research point to K bus or I bus error, anyone experience this before?? Please help...
have you check whether your battery terminal is loose?
usually, the panel beater like to disconnect the battery when they are doing the repair.
Thats the first things I checked bro.
Too many bro, mostly due to failure of communication between gm modules
My mech found a burned wire from radio today near the aircon to gm module
Hopefully that is the source of the problem.
Yes bro that's my baby. They found 5 burned wires. All due to improper connections or grounding of aux power for my GPS and galaxy.
Advice to all, don't mod your car's electronics unless the add on are custom designed for our cars
Got my car back and everything is back to normal now
Status:
Since the wire burned it also damaged two items ie Ignition switch and brake switch, cost me RM140 for both
Labor cost to find the problems and rewire RM450
Ignition switch
Brake switch
