wingzee
- Mar 17, 2011
- 1,691
JFT63;742822 said:Try swapping yr front nd rear tyres (if not a staggered set up rims)...i did that n found the culprit were the rear tyres..that solved the issue. Give it a try
Rear are staggered rims but running on non-staggered setup. all wrapped with Bridgestone Potenza RE001 with around 50% thread and manufacturing code is 2810.
Will the rear tires cause vibration in the front as well? 'Cause it seems the front floor is vibrating as well.
Will try to swap the tires this weekend. Thanks for the recommendation bro.
