Mel279
- Oct 16, 2013
- 177
- 28
hi guys
I just would like to let you know that my bimmer got problem and found out it loss compression and send to the workshop to be overhaul. Just to share, the symptom are the car keep stalling when move bit but ok on idle. It produce nasty sound and gives out continuous white smoke from the exhaust and also from the breather. Repair are in progress at the moment and new pistons and some other parts has arrive. I would need your guys advise on which engine oil grade should I use with these new pistons?
regards
Mel
regards
Mel
