E46 318i 75000km service-help needed
Adam Abdul Halim
Hi guys...any idea for 75K km service...things to check out..i will change my engine oil & filter as well...plan to do it at Ipoh...just buy this car last month...done some reading but still....macam not enough knowledge lah belajar sendiri.. :slug:E46 318i...Thanks..cheers!
Bring it to a reliable workshop to change the followings.
1. Whole coolant system including water pumps and thermostat.
2. Replace vacuum pump o ring or change it. also replace oil separator.
3. Replace all coils and plugs
4. Full service of gearbox please use GM5/6 ATF and ori filter.
5. Replace engine and gearbox mounting if old
6. Replace both engine and gearbox oil cooler.
7. Replace absorbers if car feel floaty.
8. Replace tires if they are more than 3 years old.
9. Most importantly fix all your engine leaks as this is very important and most difficult to fix.
You need a lot of LUCK bro.
Cheers
Noted with many thanks bro AS...
Really appreciated it....will bring my car to Ipoh Garage ...heard good comments bout them before...
Thanks again!!
E46 318i...
Thanks..cheers!
So low mileage ...... amazing
biasa la bro terry8.. sailors mana lepak darat lama2....hehehe..
now i pakai this car pun only 2 weeks per month...
:rock:
