E39: Oil Service Indicator Reset
vixxx
Official Member
Oil Service Indicator ResetFound this very useful. Frankly, I havent try out yet :eek:Source: http://www.bimmerfest.com/forums/showthread.php?t=398341Somebody here would like to try perhaps?!If this work, please share more info okey.Option 1
Option 2For pre 10/2000 build date...and you have the round 20 pin DLC connector in the engine bay.Instructions are at this link on how to reset SI lights (scroll down past oil change instructions): http://www.cardomain.com/ride/3134093/5WARNING: short any pins OTHER THAN #7 & #19...YOUR MISTAKE...YOUR FAULT! The pins are identified with their pin number next to them...CHECK & DOUBLE CHECK...then mark them with a paint stick or your wife's/daughter's/girlfriend's/mother's/or your own fingernail polish so that you won't make a mistake the first time or next time you reset the SI lights .
Option 1
Option 2
should be sticky!
somebody have to try and make sure that this work before this can be sticked bro :)
pussy;758641 said:
it works, ah wai of bm world does it...
bimmerholic;758685 said:
so does Naidu (aircond guy) when he does engine oil change.
Both also say they see others done it.. and not themselves.. :4: Now vixxx got to go ask the Naido aircond guy or Ah Wai of BM World.. :p
this procedure has been my practice on my previous e30,e34 and current e39.just short the related pins at the connector in the engine bay to reset the light.but like the procedure warn....don't cucuk the wrong pins!i have even tried,on my e34,cranking the starter by shorting some of these pins.
but now since i have the paSoft progamme on my lappy,i reset thru this lah.......professional sikit....konon nya lah......:sleep:
sifu already confirmed, just go ahead and do - as long as you cocok the right lobang kehkehkeh.
Thx moots
I just reset mine [E90] last nite. Oil change last month but didn't reset. So the warning finally come up and wife been complaining cause the alarm irritates her.. :p When I reset, OBC counter already at -90km.. :4:
... but E90 reset senang la. Just use the odo trip on the dash and OBC reset button on the stalk. x main cucuk.. :4:
This following video is for E39.. enjoy.. :4:
[video=youtube;SkXaa-Hs5r4]http://www.youtube.com/watch?v=SkXaa-Hs5r4[/video]
http://yimingz.com/200810/23/50.html [full write up in the link]
