E39 is coming...
ICEMAN 68;823478 said:
Just a note ....not all pressure leads to the actual cause findings immediately ....would be best to check ya tank every morning for a week or 2 ...and also do check ya driveway for traces of coolant ...
Thanks bro ICEMAN that is what I'm doing dailly now...:burnout:
anakin;823484 said:
Volvo...where's your mechanic located?btw..she'll look nicer without rear spoiler..
My mech is a former AB staff located in Taman Idaman Sg Long...
The previous owmner my nephew normally visit this mech...
So can get some info about the history of service...
Well about the spoiler I like it most without it..:rock:
Alhamdulillah dah selamat sampai kg halaman tercinta hehehe...
Elite quite jammed but from Senawang all the way to Muadzaam and Pekan smooth...
Today try the S mode during overtake it feels so good...ada ummppphhhh...:rock:
Dekat la tu bang..saya baru sampai Kuantan ni
Today DIY the fuel door actuator...
The actuator stuck or jam...
Will try to give the actuator some massat and hope it will come back to live hehehe...:top:
The actuator...
After open up to see what was stuck inside...
Manual test the motor still moving but it will stuck once in awhile...
will give some info after some masat 2moro huhuhu...
Hope it will works or else have to purchase new set...:top:
Now I think found the culprit that seeps my coolant hehehe...
Since no. 6 & no. 8 is blow the inlet manifold so even the coolant pressure test cannot see this area...
Other hose just fine no leaking but driving back home from Shah Alam to Pekan Pahang around 350km this morning check thru expansion tank the level drops about 1 tea cup...
Back in Shah Alam will replace this 2 hoses...
Cooling System Water Hoses - BMW parts catalog
P/S...Thanks to bro haywire provide me this info from RealOEM.com hehehe...:top:
Volvos525i;823854 said:
wah also kuantan ke bro gedong...
where to...:top:
otw back to KL from KT, singgah Kuantan for dinner....hehehe.....
gendong;823995 said:
Dinner 5pm in Kuantan bos. 9pm reach KL dah.....
Alhamdulillah syukur dah selamat sampai hehehe...
Today DIY my actuator fuel lid found that the motor is kaput already huhuhu...
So back in Shah Alam need to buy either new or chop shop hahaha...:smokin:
Just back from Kuantan but could not fine actuator for fuel door lid hehehe...
But got 1 set of Torx wrench very handy for UDM owner hahaha...:rock:
Just a brief updates...
Today bought some parts from BA SS2 hehehe...
1)Body Weather strip driver side rm215...
2)Door fuel lid actuator rm140...
3)Inlet pipe rm75...
4)water pipe rm190...
2moro going back home town again...
will DIY the actuator & weather strip...
Also the rear right window regulator...
so will miss TT MMZ this week...:top:
wah bro volvo....buy in ba usj and pasang in hometown?
which part of kuantan are u from?i lived in kuantan 1969-1984 .saint thomas primary n secondary
plse ensure proper beeding of the coolant once done ya.ini kereta banyak sensitip itu bleeding process...
wa...itu fuel lid actuator innards is almost the same as the boot acuator....good pics.tks
I'm staying Pekan not Kuantan hehehe...
Yup ofcoz hometown is easier due to small town so not so busy huhuhu...
Will snap some pics later hahaha...:rock:
Hi all some updates on my e39 today...
After 2 days of makan kenduri so today got some times off for my DIY session...
To replace fuel door lid actuator...
Old actuator remove from bracket...
Old & New actuator...
Top New below Old...
The bracket & Cable...
New actuator fitted to bracket with the cable & emergency cable...
Guide grommet taken out from body by turning anti-clockwise...
Since the space is quite limited so need some help here...
Push in the water pipe thru the grommet hole...
Connect the pipe to the end of the cable...
Then pull the pipe thru the grommet hole...
Fit the cable thru the grommet and install back the grommet by turning clockwise...
Then test for functining the locking cable must comes out like this...
Adjust the locking cable so that it will lock nicely by this 2 screws...
Now more secure with the fuel door lid is lock every times the car is lock...cheers...:top:
Total cost rm140 & time half an hour...
