M mika Club Guest Joined Nov 25, 2009 Messages 137 Points 0 Apr 17, 2011 #1 Any bros can enlighten me on what type of brake fluid to put in E39 ?Also, i can't seem to find the brake fluid reservoir!tried google but to no avail...Thanks!
M moots Club Guest Joined Dec 10, 2004 Messages 1,600 Points 83 Apr 17, 2011 #2 use dot 4.....any branded ones shud be ok the master pump/reservoir is under the rh cabin air filter housing assembly
M mika Club Guest Joined Nov 25, 2009 Messages 137 Points 0 Apr 18, 2011 #3 moots;627661 said: use dot 4.....any branded ones shud be ok the master pump/reservoir is under the rh cabin air filter housing assembly Click to expand... thanks bro!
