I just replaced mine not long ago and facing the same issue as yours. Recheck again and found out that one socket not plugged. Once plugged in everything become normal again.
Another possibility is you might need to set it? Press the down button and don't release it till the window is totally down and then press the up button, same do not release it till the window is totally closed. Repeat it for few times and it shall solve the issue.
