E36 328i Cold Start Issue
seanswn
Sifus,Having Issue with my car during cold start.It will died off once it is started when it is cold.Or, if it is not too cold, it will under idle, engine shaking, dieing symptom.If it is Hot, no problem.Any idea ? I tried to replace MAF from another 328i but same issue.
Hi bro,
Pls check ur idling valve, could be dirty , need to be clean . perhaps ignition coil or throttle body somewhere clogged. Thanks.
Issue resolved, due to leaking pressure valve (the one mounted below the manifold).
Thanks for the help.
how does sound?.. like normal?.. or noisy... which workshop did you go?
Perhaps head gasket engine leaked. Some fluid enter into your piston and rod. That why engine shaking
