E36 318 Auto - power
turbology
I test drove friend's 96 318 today.His car is stock.At gear 1 (not D), the car barely move. The power is worse than a Wira 1.3.Is this normal ?Or I being spoiled ?
How often the owner do the regular maintenance is the key point..
something must be wrong with the engine or transmission...
it should not be that bad.
planta
Worse than wira 1.3?? hahaha. Come test my E36 318 lar. Not power like your car lar but not worse than any 1.6 japs. :smokin:
Although M43 got only 8 valve but the smallest still bigger than the biggest jap or proton megavalve. For me I dun feel much different wt my 528 for low end torque & speed. Higher speed dun compare 4 pot wt 6 pots lar.
Agree, I have not tested the 318i Auto yet but the stock 316i Manual (M43B16 engine with only K&N drop-in filter) no problem hitting 195km/hour on NS Highway.
His car is stock.
Is this normal ?
This can be short circuit...., cannot be detect by OBD2 diags..
maybe from the alarm?...??
try to check the battery current drain rate..
