folks, i'm planning a diy on the fan clutch replacement. i have a 32mm wrench - what i'm struggling with is the safest way to hold the water pump pulley - i know it has 4 10mm hex nuts - could i use 1 10mm wrench to grip one of the nuts to hold the pulley still while i turn the 32mm wrench clockwise to loosen the fan nut?i know there is supposed to be a water pump pulley "hold" tool but i don't have it - is there a design template which i can machine off a steel ruler ?
