lawsarus
- Dec 13, 2009
- 87
View attachment 12582View attachment 12581I got a 2003 325i as my very 1st bimmer in Bahrain, Middle East two weeks ago and yes i'm very happy until i sent her to the dealer, Euromotors, for a check-up to rattling sounds at the front. the service advisor faxed me a list.Description (AMOUNT)1. Replacing front & rear brakes discs, pads, sensor, lubricant (630)2. Removing & installing power steering gear, WHeel alignment check KDS up to design load, Rmfd strng g, ATF D III Gasket Ring, coupling (831)3. Replacing rubber mount for transmission mounting Replacing both engine mounts (no parts n i have to wait for a week) (110)4. Removing & installing or replacing front stabilizer, swing support (33)5. Replacing both front spring strut mounts, Set brackets (127)6. Removing & installing/sealing or replacing oil pan Carrier & Gasket (250)7. Removing & installing/sealing or replacing complete full flow oil filter Oil pipe & Gasket ring (64)8. Removing & installing/sealing or replacing rubber frame for windshield cover (43)9. Replacing alternator drive belt, fan belt (33)10. Others (which i can make it out myself) (58)GRAND TOTAL: Bahraini Dinars BD 1,909.00BD 1.00 = RM 9.30RM 17,753.70 I totally understand that we have a different climate here & im not sure how much different does it make but i cant afford to do such repairs. i was only able to pay for some repairs of my choice which already sum up to almost RM 4K. It will also take 4 days with no courtesy car. Are the above mentioned repair really required? Bimmer is really dear to maintain...
