Grand;698062 said:
Went to Lim Tayar Taman Tun Dr Ismail as the car was veering slightly to the left. Was charged RM60 for alignment and RM160 (RM80 each) for adjusting the chamber of both rear wheel. Total comes to about RM233 including govt tax. However the problem still remain. Car still veer to the left. The guy then suggested that I also adjust the front wheel chamber for RM200 (RM100 each). He said the charges are higher as front wheel is more complicated. I thought I read that the chamber of E90 is dead and cannot be adjusted. But not sure about E60. The guy insists that the chamber for E60's front wheel can be adjusted. Anyway did not do it as i think the charges are too expensive. So please beware when going to Lim Tayar.
Just to share an expensive info at LT TTDI. My E60 have done the front chamber adjustment 4 months ago at LT. There is suppose a fix front chamber.
Below is how they do it:
When you open your bonnet, look at the top mounting of each shock absorber.
You can see 3 bolts. At the bottom of each bolts there are elongated holes (oblonged oval shape), that is meant for left right adjustment(s).
But there is a slight problem before you can adjust the top mounting. When you inspect further next to the 3 bolts there are 2 small holes. One has a pin and another is just hole. Same for L and R.
To remove these pins, just use a sharp object (e.g. phillips-head screwdriver) to punch from the top. This is an eye sore moment as the foreman has to brutally use a big hammer to kang-kang-kang until the pin drop into the shock absorber cover below.
Both pins can't be found on the floor.
Then loosen the 3 bolts on both sides and adjust to the desired L or R.
Before this, my E60 tends to go to the left and I always got to pull the steering slightly to the right.
So the setting is to set 6 bolts to the right of the driver. So the car has the tendency to the right. Now my car is balanced. Left + Right = Happy driver.
This front chamber setting is very minimal only. If your car pull heavily to one side, this might not solve your problem. In my humble opinion.
Before this, I have tried many shops to solve this problem. Change tyre, change rims, change absorbers but still can't get rid of the L
