e 36 manual-need advice
subsevend
helo all sifus.i ve always dreamt of getting a beemer.but just too scared,many people say parts expensive,maintenance high,if gearbox kong very expensive,workshops dont know how to do and all..i thought might as well get info from the users and experts here instead of listening to others.I m eyeing on manual e36 beemer.Anything that i must see before getting it?thanks in advance
If you are interested in a 318 (M), send me a PM...for advice, you can search through the threads you can get plenty of info.
I have a 318 (M). If you don't do any modifications, I believe your fuel consumption should be equal to a perdana. The manual gearbox cost is cheaper, compared to the auto however. 2nd hand Parts from chop shops is cheap (100-600RM) depending upon the part. New and original engine parts should set you back RM 1000+.
e36 manual-need advice
Thank you bro
i m eyeing on a e36-325i.i heard its better than 318.is it true?
one guy suggested do EDC for bmws,should i do it as well?
any parts that gives problem most of the time?
i shall check the thread as well.
thanks again bros
subsevend;536928 said:
Thank you bro
thanks again bros
Hi bro,
The 318 is a 4-cylinder, 325 is 6-cylinder. 2.5L More engine power, more fuel consumption. 318 is a little under powered, since the car is heavier, 318 manual is still better compared to auto, however. 325 also has vanos. I believe the engine parts will be similar cost (or little higher) for 325 as compared to 318. The 325 can have additional sensors, such as ASC, depending upon the year/model.
The parts to check when you buy a car will be the front and back shocks, steering rack, radiator.
Most of the problems in bmws are either the sensors, cooling system (radiator, water pump, compressor etc), electrical wiring alternator, etc. Also check for any oil leaks throughout the car, if there is a leak, then that has to be fixed.
Take the car to a reliable mechanic before you buy it. Initially, you will have to spend some money on repairs, when you get the car (unless it is in perfect condition). After that your maintenance cost should be lower.
After you buy the car, you can do a full inspection (including the computer one), which can tell you what sensors are working, what are faulty.
Dear subsevend,
Myself had just acquired a 1995 E36 325 (M) in April and been using it as a daily driver for almost 2 months. I was exactly like you, doing a thorough research and finally decided that a manual tranny suits my needs of a beemer (not that autos is not good). Been doing serious research since 2006!
My advise to you in preventing forking out thousands of dollars upon buying a beemer is (apart from the usual taking the car to a trusted bmw specialist for inspection) to get a maintenance report of the car you gonna buy. With it you can know what parts that you MUST change upon buying the car, so if the unchanged parts list is long you know you're gonna be a bit pokai "immediately" after buying it thus the decision is in your hand when that knowledge is yours. Comparing to buying a beemer without a complete maintenance record, the costs of some wear n tear parts might shock us to the point of heart attack.
Myself, upon getting the car, 3 wear n tear items have reached it's time and had to be replaced. 1 fuel pump + 2 floats, driver side window regulator and radiator expansion tank, items which when i checked the maintenance record have never been changed for 15 yrs! IMO not bad for a beemer! The window regulator has rivets holding it meaning it is original item from the factory 15yrs ago. We have to grind it off to take it out.
Other than that, the car works beautifully and now i understand what beemer owners rave about. Not to brag but i always find a reason to drive my car...Coincidentally the previous owner is a member here zulcar9ne.
Been to Mersing to and fro without problems early this month and it's a wonderful feeling. Take my advise, don't rush and make your choice wisely!
e36 325 MANUAL...the way to go..keep hunting bro and gudluck..1 piece advise for you..dont rush to get 1,i waited almost a year to get one..used as a daily drive,almost 30km per day since march,things done..fuel pump,water pump,battery and aircond belt..other than that..superb and no regrets!
ohh 5150 ..that's a rare find as ya unit is the original that was brought in by AB ...glad that you're enjoying it ...
a note to subseven ...just feel what ya hearts say ...if yes go ahead , if no then no point getting one and not being able to maintain it ... of course the journey would be tireless and moolah would be flying high ...but it boils down on what is needed to be changed and some could be prolong towards later on .....
if you've got a complete car with all rims and bodykits ..then it would save you the hassle of sourcing the cosmetic stuff ..and you'll need to concentrate on the engine part ....
enjoy ya hunt ....
Thx iceman, IMHO it was well maintained by previous owners and although the price was a bit high but i guess it's justified....i'm still learning to master the car btw...:wink:
From The President's Announcement,
The 11th Charity Jam Session would be held back at RP , Saujana Resort (formerly known as Hyatt Regency Saujana) again this year which would be held on the 3rd of July, 2010 (Saturday). The event will be spearheaded by Malaysian Association of Hotels, Chefs Association of Malaysia, Malaysian Food & Beverage Executives Association and Malaysian Association of Housekeepers with The Saujana Hotel being the venue/co-organiser with participation of BMW Club Malaysia.
Activities for the day would include, performance by 17 bands from around Malaysia, car (BMW :rock:) display outside RP, biker's display etc. This occasion will further be promoted by the media with coverage in major newspaper's and magazines.
Proceeds to : Paediatric Intensive Care Unit (UMMC, KL), a dedicated care unit for the critically ill children from newborn to fourteen years of age. All proceeds will be used to purchase life saving equipment and subsidize the cost to care for these children.
Prior to this, affiliation was done with other clubs such as Porsche Club Malaysia , Harley Davidson etc . This year and with your help , maybe years to come we are proud to be associated with this noble event.
Day/Date : Saturday 3rd July 2010
Time : 2.00pm – 1.00am
Venue : RP Entertainment Centre (Tel : 03-78461234)
Saujana Resort,
Off Jalan Lapangan Terbang Subang.
Bands Performing :
Fats & Vernon
Zack & Lyia
Ghost Riders
Extreme
Union
Bala
Joe "Elvis" Rozario
President's Men
Sensations
Shahrin Band
Chemistry
Carbolic Smokeballs
Trinity
SWV
Pieces of April
SmallStones
d'Stags
The event will be filled with fun, food, music and booths selling merchandises...
All food and beverages (including Carlsberg Draft/Skol Beer/Fruit Juices) are priced at RM10.00 and are sold via coupons available through the Organisers & official partner BMW Club Malaysia and also at The Saujana Kuala Lumpur. Priced at RM100.00 per book of 10 coupons. Additional single coupons of RM10 can be purchased during the event.
There will be lucky draws using the coupons during the event. Attractive prizes such as handphones etc will be given away. Fun Auctions will also be held throughout the day.
We are proud to be the official partner for this noble event. As such , lets make us proud by helping the needy children as MUCH as we can. Lets strive to be the record breaker for the donation. They might not be our children but they could have been. So, lets give and give generously. Don't stop at individual donations. If u know of corporations willing to donate, please do make the effort. Donations will be in the form of coupons booklet. Each booklet contains ten coupons of RM10 which makes it RM100 per booklet/donation. Donations be it small or big are very much welcomed.
The coupons are to be used to purchase food & drinks as well as enter lucky draws throughout the day , if u attend the charity jam. U can also choose to just purchase the coupons purely as donations.
The donations (coupon purchase ) can be used for income tax deductions. As such, to those needing the receipts, please advise us of your details and we will arrange with the main organizers for the official receipts. It was requested that donations of RM200 and above request for the receipts due to the organizers logistical reasons. However if u do need receipts for Rm100 coupon purchase , I will forward the requests.
So come..come all to have fun while donating to a noble cause.
If you're looking to perform repairs yourself, I would highly recommend investing in Peake diagnostic tool which paid off for me. I've bought both the SRS and engine diagnostic tool and was able to fix all the problems with my 328i. Key thing to remember with Beemers ... follow the maintenance program. Purchase a Bentley manual as it is a bible for BMW owners.
There are a few maintenance routine I follow .... I flush and replace my coolant every 2 years, flush and replace my brakes fluid every 2 years, changed plugs annually. I've also replaced my differential fluid and manual tranny fluid. These are economical maint. programs you can easily do yourself.
