B33mEr;599520 said:Labour charges are very expensive in the UK and in the US hence why the DIY culture ... Over here labour is pretty cheap while the parts are expensive.
Talking about oil change i wonder if there any similar products in m'sia like the pics below? It's the Mivetac oil extractor with a capacity of 8.8 liters. Suitable for 6 cylinder BMW engine. Makes short work of oil change and you can dispose the oil at most workshop.
USD70
bmw7833;599578 said:U will surprise when u read the oversea forum, they almost DIY everything.
redlotus;599870 said:You guys jack up the car youselves using the carjack? Enough height to fully drain?
astroboy;599612 said:haha! we only DIY make babies.. :3:
astroboy;599875 said:
redlotus;599880 said:Thanks astroboy. Good article there. Yeah 25-40Nm was what was recommended by TotalBMW when tightening the oil filter cap, even suggested to be lesser than the sump plug. You didn't fit a copper seal before screwing the sump plug in? And while the sump plug may be easier to reach in a smaller sized car (e90) did you face any problems reaching for it in an e39? One jack enough? Left/right no difference I suppose? Or did you use two?...
USD70
