Disc/brake pads change for e90 325
Beemerdude
Guys,Anyone can recommend a good plc, reasonably priced, good workmanship to do the above? Called a few places and the prices vary...so getting a bit unsure. Some places quoted lower rates because they claim should use ori for front but could use oem for rear...appreciate any advice.Thanks.
Beemerdude;702683 said:
Guys,
Thanks.
Try Ultimate Motorsports in Batu Caves. I just changed my rear brake pads a month ago. So far so good. Use OEM.
Strangely the rears wear out faster than the fronts. FYI only.
Where are you located at? i change mine at subang SS18, Bavarian auto parts is just a few shops away from my mechanic and they get all original parts from them..
Dear powerlun, how much they charged you?
You can get good quality German made OEM from places like Stuttgart and Auto bavaria in SS2, then u can install in your normal workshop.
I decided to get slotted rotors from Motorsport division in sunway, it was about rm2.5k for front and rears. (only slightly more ex then ori BMW)
I just changed my 320i E90 to brembo brake disc,brake pad and sensor last week for about RM2200 at universal auto garage sg buloh. not sure is it same size as 325i.
Is this for front and rear / or front only?
Thanks.
Aeroboy;722711 said:
Wow good buy! Way cheaper than the BMW Performance set!
Do share pics!
its cheap bcoz its only disc & pad...BMW performance comes with 6-pot caliper thats y its expensive ;)
I think for BMW Performance BBK somewhere in the vicinity of RM6,500. Also made by Brembo for BMW. Of course together with 6-pot calipers.
Thanks everyone for the info.
Havent changed them yet but warning lights just came on just so i gotsa do it. Thinking of going to M1 at segambut dlm..budgetting 4k...yes?
wow.. so how about the gripness? is it better than the stock one? mine 320i E90 also need to change a.s.a.g.m (as soon as got money)
:D
hankeymeal;722625 said:
Front and Rear disc and pad. All Brembo.
maybe can try Zimmerman sport cross drilled disc with ori TRW pads. It will perform better
