CrusheD_LameR
- Jun 7, 2011
- 4
Hi,been searching the forum for the past few days, I want to ask, when i drive an e34 520i manual, and try to shift from 1st gear to 2nd gear, the gear knob vibrate and produce a cracking sound...kreeek....before sending it off to the hospital, I want to know what is the possible cause?you see, the sound is like when you drive your car forward(most car, my myvi also same), and you try to shift to reverse gear while the car was not fully stop, and the gear will produce this kind of cracking sound...what happen haa? is it the clutch? I do think, if I tarik or tighten or shorter the clutch (so I just can step on the clutch paddle and depress it a little) please shed some light to me guys...and the cost for the possible cause of the problem...thanks in advance...
