Clutch pedal dead, Gear locked
skar19
Retired
This is a reccuring problem which happens only when i shift gears a lot, when i drive my car hard this happens, the pedal goes soft and the shifter cant engage or the shifter is locked (if in gear). Sent it to a few mechanics they change something but still it happens. The funny thing is it always happens on the NPE and Kerinchi Link toll.
there could be air in the system......
suggest you flush clutch fluid totally then see if it happens
if it still happens, don't use the highway....got ghost disturbing you dude...!!!!!
Put lots of garlic into ur car :rofl: :rofl: .
Back to topic, it happens to me few years back. The clutch pedal become softer & softer, & finally had to fully depress to floor panel to engage gear. Later found out that a spring in clutch cylinder torn off
well there are few suggestion out there try first I had not expreience of this kind except on my Austin.
thaanks TJ i ll try that
somehow i knew someone would say that hahaaha :D
