Anybody experience some problem with E46 central locking:-
Just experience a strange problem with my central locking on Saturday.
1. Cannot open the all the doors by the internal "Open Door" push button.
2. Cannot open the driver door by the remote control. However, the windows opens when continuously press the "->" (or unlock button on the remote control).
3. Can lock all doors when the remote "lock" button or "internal push button" is pressed. Can also open the rear boot when the remote "boot" PB is pressed.
4. When press the "internal open door", there was a slight click but the door did not open.
5. When press the lock key on remote, the door cannot be open from inside lever. Got me worried for a while as could not get out of the car. Luckily can open the window and use key to manually unlock the door.:wink:
6. Try to disconnect the battery supply to recycle the EWS, ECU and whatnot. Did not work.:stupid:
Yesterday on Sunday, the alarm went off for no reason.. Press the "->" and alarm is silenced.
Try to open and close door and found that every thing just work perfectly.. :love:
Note: Found that the driver side only have key lock whereas the passenger side door does not have any lock (similar to the rear door handle)
