CD player RESTART when the BASS is too LOW
albertsew
I am using JVC single disc player and using JVC speakers as well. It seems that my player cannot play "BOMBASTIC" music, whenever it play with low BASS, the player will RESTARTMy Bass is set at 2, max is 6 . And I always switch on the LOUDNESS.Why like dat ar ?for E34, anyone mount a LCD display before ? Which is the best play to mount so that it would not block my air vent ?
check if ur alternator is charging enuf loh....maybe ur battery is weak.
mine oso,just changed to kenwood mp3 player,.if i blast out loud,it will reset (off then on again)
How to check if my alternator is time to go ?
Else I would change to a new battery
Ha ha, in my other car, when I turned up the volume and bass, my headlights went into "disco" mode.... :D but the player did not reset. Found out my alternator was not charging properly by my mech. Had it serviced and all ok now.
Why don't everybody get a volt meter from Calvin Tan so that we always know the condition of our power supply.
Calvin, any special rate for us. :D :D :D
