can we make sure aircond OFF when car OFF?
leakwoon
wat i knew so far was the aircond is programmed like tat for euro.when we turn the car key.... the air cond is auto ON.it will hurt the battery rite?? :beaten: btw... wat battery u guys using??thinking to change my soon thanks
Your topic has been towed to the appropriate section, in the future please refer to the main forum page for guidance.
There will be a link from the original place of posting leading to the new place (This states the approriate place).
If this thread is a tech question and if you are not sure which catergory to post under, please post under general tech.
If this thread is a 'FS or WTB' then post in the classifieds.
Thank You
-The Moderator
haha
tat's the problem i wan to resolve
bro kinaka... u not aware of this isn't it...
wat i heard the aircond is pre-programmed to be like tat !
You could probably reprogramme it through the MODIC thingamagic
Do you mean the AC blower is still running? Or the electric fan?
take it to a workshop which has a diagnostic tool and tell them your problem. hopefully they can sort it out
guys..if u r not sure or do not have the climate contol a/c..pls refrain from commenting..actually the a/c is not switched on..only the blower..theres no additional load on the battery..the compressor will only kick in after you have started the car..no worries..all the climate control a/c for bmw are programmed this way..dont fixed something which is not broken..trust the BMW engineers in Bavaria..
aiks, mine is b4 i got out i off my a/c, when i ignite back, it still stays as off but in my fren's e46, no matter how many i off it, it will turn on even though i have switched it off..
maybe it gotta do with the progs... i think u gotta reprogram it back.. as our car is meant to suit our preference, maybe the ex-owner preferred it to be swithc on when the engine is on..! hopefully it helps..!
That doesn't seem to be the case with mine..
Before I kill the engine, I turn of the AC/compressor, but not the Blower.
When I start the car again, the Blower is on, and I have to manually activate the AC.
If I turn off the Blower before killing engine, when I restart the next time, the Blower comes on by itself.
Hope that helps..
If your AC/compressor is coming on by itself even after switching off, then maybe that's not normal????
i m lost
u mean the AC button ....like a "cool" button??
in between the demist of rear windscreen?
yeah..
dat be the one
It turns on and off the AC compressor...
Otherwise your blower is just blowing hot air.
Originally posted by leakwoon@Mar 13 2006, 10:38 AM
so have to go back to autobavaria to re-programmed it?
i think no nd AB le. any mechanics tat have the diagnostic device will be able to help. but make sure its a trustable n experience mech if u dunwan them to screw up on yr other progs.!
