maxion89;738257 said:Oh icic...well later i snap a picture of it...my bad not be so carefull... now its really hard to find a replacement...
maxion89;738238 said:Hi guys,this question might sound crazy but here it is. Broken camshaft is it possible to be use again? i mean still can make the engine working?
Petrus;739535 said:Right Parts and Parts Corridor are both in kolombong. They sell bmw and merc parts there. If u go to AB (now known as FM Autohaus) sure very expensive.
Try going to kolombong and search for these two shops If u know where is Fajar Motor, then it is at the same block
owm;739801 said:You tried Eng Soon in Singapore?:
http://www.engsoon.com.sg/about.php
If you want cheap, then only used is an option. Posting on overseas BMW forums should be your best bet!
PS: 1st time I have seen a broken camshaft!
moots;739960 said:yowzer......now that is one.....or shud i say 2.....broken camshafts.normally camshafts break when they are mishandled....like removing them incorrectly....like not releasing the camshaft holder evenly.and also if one drops the camshaft.other than that...i donno.but broken rocker arms got la....as i experienced it myself....twice....:wink:
dominic;739985 said:Hi bro
I have a set high cam shaft for e39 528i for single vanos
Engine
Don't know can used or not
Let go cheap for u ya
Mr Lew 0123892269
Tks
