anaksarawak
Official Member
- Jan 20, 2007
- 4,154
anaksarawak;790916 said:Jarance, can I come at night? Busy during work hours due to clearing work in preparation for Xmas n New Year
Strider74;790957 said:Bro, im not experienced in BMW DIY...yet.
But i do have some experience with electricals and electronics.
Try cleaning the contacts with contact cleaner, an alcohol based cleaner.
I'm guessing something is shorted , thats why your signal lights are on.
The sensor sense that as an overload.
Need to find what is common between those lights.
consoglieri;790962 said:AS, had problem with mine earlier. All lights are ok, but warning indicator was on. Rear left light was the culprit. Replaced the housing and indicator gone. However, this was common issue with all E92 before facelift. Was informed by the workshop, this usually happens when u meddle with the lightings. Have u added additional lights that might have caused the problem?
pussy;790963 said:bro, this wiring is all link up to the CKM or LKM of the car. the fault is not directly link to the signal lights but can be due to other faults. one of my seven head light adjustable motor is faulty but the check control will say my rear number plate lights is blown. if I unplug the motor, it will not fault up. this mostly happens when the car gets older. wires n electronics getting frail n ohm plus voltage drop.
you need to do a manual plug/unplug trouble shooting to find the problem. another possibility is water in the sockets, need to dry them.
aidilj;790974 said:Angel eyes recently installed? How is it powered? Rarely that both side of lights go bad at the same time..
anaksarawak;790975 said:Angel eyes was installed at WRC and they still work.
aidilj;790979 said:Did they remove the parking lights bulb to power the angel eyes?
http://www.bmwclubmalaysia.com/foru...-FX-R-retrofit&p=661490&viewfull=1#post661490
and bulb check can be coded out, no need resistor
http://www.bmwclubmalaysia.com/foru...2-E46-318i-CKD&p=748051&viewfull=1#post748051
