zidee
Active Member
- May 18, 2010
- 571
- 28
I stumble this lightweight application that finally can read my 1 Series E87 N46 engine. Best part of it is that it can run on Mac OS. Mac OS install file is only 10.5 MB and for Windows its much smaller. Only 5.3 MB. You need to use K+DCAN cable that commonly used with INPA/DIS/GT1/NCS ExpertBMWLogger allows you to log data from your BMW in real-time. Simple to use application although at this stage its only meant to read and clear DME. Public release is free but it does not do data logging. You need to pay for. It gave the code error but did not give description of the error code. You have to find it. For now free version is good enough for me to :1. Read and clear DME error2. Register battery for IBS (Intelligent Battery Sensor). It does not Recode Amperage Values Into Your Module. This Only Resets IBS For A New Battery3. Clear adaptationCurrently This Public Release Fully Supports MSS60, MSS65, MSS70, MSV70, MSV80, MSV80.1, MSD80, MSD81, and MSD85.Registering A New Battery With IBS Works For All 03/2007 and newer gasoline vehicles that use the IBS system.For MS41, MS42, MS43, MS45, MSS50, MSS52, and MSS54 please see other product page at http://bimmersoftware.com/BMWLogger You can read the forum posting at :http://www.e90post.com/forums/showthread.php?t=727091
