tongsatriani
- Jun 24, 2005
- 594
- 18
If no ATF change done before, don't do it!
If done before, change it as per recommended.
funfer_fahrer said:Tongsatriani,
Somebody once told me about this. Is there any technical explanation?![]()
Perhaps you should get in touch with the engineering department in ZF for explanation. The modern auto gearbox itself is, to me, more complicated than the engine. Most of us here can only share experiences.funfer_fahrer said:Fab,
Thanks for the thread. But most of the discussions don't really answer my question. Some are mere suggestions and experience-based explanations.
tongsatriani said:If no ATF change done before, don't do it!
wglee said:I guess the adage "if it ain't broke, don't fix it!" applies in the case of high mileage cars which never had an ATF change.
change driver....3er said:Mine aint broke. Its just wonky. What do i do?![]()
wglee said:Having noted the various opinions profferred, I'm still unsure whether I should replace my 5 year old ATF. The ATF replacement job in itself is not that costly, but I'm just afraid the consequences of that job are! My car's gearbox works fine (touch wood) and I don't want to upset the status quo.
