1)Open E-sys and chose connection via Vin and press connect
2)
Select F010 Without Direct
3)Select Expert Mode - Coding ,Read & Save - Edit
4)Expand the FA list folder until SALAPA-Element is show
5)Select SALAPA-Element Folder then add 6WB at bottom box
6)
1.save > 2.select file and calculate FP > 3.save at file
7)Select Expert Mode > VCM > 1. Load you FA file > 2. Right-click on FA and Calculate FP again
8) 1.Select VCM Master > 2. Click on the Write FA FP button
9)Expect Mode > Coding > Read FA file > Click FA file & Activate FA
10) Read SVT
11)
Left Click Dkombi > Click Detect CAF for SWE > Select the CAFD Latest Version[the bigger number] > Select OK > Right Click on DKombi > Select Code
~Finish~
Item Needed :OBD Enet Cable arround RM2-3X & 6WB
Software Needed : E-sys & PSdZData*Lite Version is enough*
Please do it by u own risk, make sure backup Old Device FA file
2)
6)
10) Read SVT
11)
~Finish~
