BMW E46 SMG Coding with BMW ICOM WinKFP software
jankenda
New Member
Here is an example of coding BMW E46 M3 (with SMG2 transmission) Euro SMG mode also called "CSL Coding" with BMW ICOM engineering and developing WinKFP coding software.
Equipment:
BMW ICOM ISTA/D ISTA/P with WinKFP 5.1.6 or newer version software HDD and 46 data files
BMW ICOM A2+B+C diagnostic and programming tool
Stable power supply 13-14V at 10A (very important)
Instruction:
1) Configure WinKFP
Well install BMW ICOM ISTA/D ISTA/P software HDD
Select and run WinKFP software on the desktop
Click Import/Export ->Import ->Assembly Line Data
Browse to the unzipped SP-Daten-E46 folder and select the “data” folder. Press “OK” and wait a few minutes to load the data.
Click “Configuration” and do some settings, language, file destination etc, make sure the program configuration setting is the same as picture below:
Save settings and exit WinKFP software.
2) Flash/Program CSL module
Browse the unzipped SP-Daten-E46 folder to:
Copy the contents of the ecu folder to C:/EDIABAS/Ecu
Copy the contents of the sgdat folder to C:/EC-APPS/NFS/SGDAT
Run WinKFP software again
Turn ignition ON
NOTE: Keep the vehicle voltage at 13-14V. If the voltage is below 12.5V or above 14.5V, the flashing procedure may fail and results in brick the module.
Run WinKFP and select “Comfort Mode”
Click “Enter ZUSB”, select ECU type: GDSMG2 and choose ZB-number: 7843255. Click OK.
Click “Enter VIN” and manually enter 17-digit VIN correctly
Press “Done” You will be displayed the vehicle information and the boost section update activated message.
Click “F3: Program”. WinKFP will give you a message about having X number of flashes available. Press Ok to accept the notice
The module flashing is processing. Accept the windows prompt if the flashing stops at 100%. And it will go faster and complete programming.
Turn ignition OFF
Turn ignition ON after 5 minutes. Clear the stored DTCs in control module with BMW INPA software.
Turn the ignition off and wait a few minutes again if the transmission error light is still on.
Start the engine and enjoy the improved shifts. You may need to run the SMG adaptation procedures.
The whole procedure takes about 15 to 30 minutes. Do not exit the software program or disconnect the BMW ICOM diagnostic tool with vehicle, otherwise, the SMG module will be bricked.
http://bmwicomseries.webs.com/
