One of our customer use 2015.7 BMW ICOM software and get the following prompt:
Error:
Data is only stored locally. Thus the process for overlapping cooperation is not available.
Cause: ISPI Process services not available (IPS fault code V999)
Note: The status of ISPI process services can be determined using the function ‘IPS Check’ in the ISPI Admin Client.
Software gives prompt, after i click OK. He test ISTA P, ISTA D and other options, all works normally. This will have influence for usage? Can i remove it?
Answer: For bmw icom after 2015.7. This is the normal prompt. Just click OK and go on to use this software. It has no influence for software functions.
More information: http://www.obdexpress.co.uk/search/?q=bmw+icom
Error:
