Latest update:
Diagnostics Tool connection succeded! Borrowed a laptop from a friend that is running on Windows XP and it runs fine. No issue with the USB to Serial adapter...so actually the program does not support Vista but works fine in XP.
Now video on the move is enabled, will be able to watch the TV on the move (well I know its dangerous, but I wont watch it..mainly for the passagers)
So the next thing is to DIY the AV connection to allow Audio/Video input from a DVD player or my iPod..will update about that later.
Oh just to let you know the tool also allows you to change the odometer reading, change the unit from Miles to KM (which I have been researching for a while but have not find a good solution yet! Now got that feature, easily change to KM once i go back to Malaysia). And it also can do a service light reset.
There's a lot more use to it..but I dont actually know if its actually useful to check the running condition of the engine since its mostly deals only with the electronic stuff..
This is the list of things it can do:
Workable Models:
This interface works on all BMW E38/E39/E46/E53/E83 upto 2004
E38 - 7 Series
E39 - 5 Series
E46 - 3 Series
E53 - X5 Series
E83 - X3 series
Main Functions:
[FIND UNITS] -scanning installed units with reading identification data and malfunction codes
[CLEAR ERRORS] -reset fault codes in all of found units
[ERRORS DETAILS] -detail info about malfunction codes
[READ MEMORY] -reading unit software memory
[READ EEPROM] -reading EEPROM in units: IKE, LCM, ZKE, SRS, LEW, A/C, VID, BMBT, STH, AIC...
[WRITE EEPROM] -writing EEPROM in same units
[ERRORS] -reading detail info and reset malfunction codes in selected unit
[RESET UNIT] -unit software reset
[WRITE FGSTNR] -identification number writing
[WRITE ADFG] -more identification data writing
[ODOMETER CORRECT] -writing new mileage value to IKE & LCM units
[SAVED ODOMETER] -reading more detail info about mileage from IKE & EGS units
[SERVICE RESET] -IKE service reset
[CHANGE LANGUAGE] -changing language of main computer messages GE/EN/FR/IT
[FACTORY DEFAULTS] -factory defaults reset of IKE & LCM (for cars till 1999 year)
[COPY CODING] -base coding copying IKE to EWS or EWS to IKE units
[TV FUNCTIONS] -"video on when driving" setting in VID unit
[READ KEY] -reading ignition keys data from EWS unit
[ADAPTATION LEW] -steering wheel sensor (LEW) adaptation
[REGISTER HANDSET] -new handset register to TEL (BIT2) unit
Some of the systems accessible with this device:
DME-Digital Motor Electronics E38/E39/E46/E53 up to 2004
EGS-Electronics gearbox control E38/E39/E46/E53 up to 2004
EWS-Electronics car immobilisation system E38/E39/E46/E53 up to 2004
ABS-antilock-braking system with ASC/DSC E38/E39/E46/E53 up to 2004
EHC-electronic height control E38/E39/E46/E53 up to 2004
A/C E38/E39/E46/E53 up to 2004
FGB-Rear compartment blower E38/E39/E46/E53 up to 2004
SRS-Supplemental restraint system E38/E39/E46/E53 up to 2004
IKE-instrument cluster electronics E38/E39/E46/E53 up to 2004
Mileage correction on E38/E39 with 93s56/66 chips AND mileage correction on E46 to sw15
LCM-Light check modules E38/E39/E46/E53 up to 2004
GR2-Cruise control E38/E39/E46/E53 up to 2004
PDC-Park distance control E38/E39/E46/E53 up to 2004
AIC-Automatic interval control E38/E39/E46/E53 up to 2004
RAD-Radio E38/E39/E46/E53 up to 2004
SZM-Switching centre, centre console E38/E39/E46/E53 up to 2004
NAV-Navigation system E38/E39/E46/E53 up to 2004
MID-Multi-info dispaly E38/E39/E46/E53 up to 2004
ZKE-Central body electronics E38/E39/E46/E53 up to 2004
SMB-Passenger seat memory E38/E39/E46/E53 up to 2004
LSM-Seat/steering wheel memory E38/E39/E46/E53 up to 2004
EDC-Electronic damper control E38/E39/E46/E53 up to 2004
LEW-Steering angle sensor E38/E39/E46/E53 up to 2004
RDC-Tyre pressure check E38/E39/E46/E53 up to 2004
MFL-Multi-function steering wheel E38/E39/E46/E53 up to 2004
DSP-Digital sound processor E38/E39/E46/E53 up to 2004
BMBT-On-board monitor, control panel E38/E39/E46/E53 up to 2004
VID-Video Mdule E38/E39/E46/E53 up to 2004
SES-Language input system E38/E39/E46/E53 up to 2004
Tel-car telephone E38/E39/E46/E53 up to 2004
HKM-Boot lid module E38/E39/E46/E53 up to 2004
LRA-Automatic headlight vertical aim control E38/E39/E46/E53 up to 2004
FID-Multi info display rear E38/E39/E46/E53 up to 2004
NAJ-Japanese navigation system E38/E39/E46/E53 up to 2004
