bmw e36 interior noise!!
enkil;455920 said:
Not really. Go and compare the prices with normal workshops. I got the engine oil filters at RM 17. Normal workshop charges RM 35 to RM 45 for the same thing. Haven't check the clip prices though. Do a bit of homework and you can really save a lot on these little parts.
Cheers
uurrrmmm.... we are talking about clips prices here...:rolleyes:
sesat88;455819 said:
the BMW center in Glenmarie got sell ka?
yes u can buy the panel door clip at glenmarie..looh Mr Vasu pic..for Sparepart Department..
get those door clip in glemarie as the price is much more cheaper that some of the spare parts shops ...the difference in price is huge ... can take your whole family for a dinner meal ....
OK ..something that i would like to share is ...if you're gonna replace the clip...u need to install it with a DIY rubber spacer ...yahhh where to find t rubber spacer ?? get those tyre tiubs in the tyre shop ..a used one or the thrown one ...
all you need to do is cut the tiub to a 10cent coin size and make a hole in the middle .... fit the rubber spacer into your newly purchase clip and VIOLAAAA the sound dissapears soon after you've install it back
HAPPY modding dude's
ICEMAN 13;456056 said:
get those door clip in glemarie as the price is much more cheaper that some of the spare parts shops ...the difference is price is huge ... can take your whole family for a dinner meal ....
Good one, iceman13... :top::top::top: btw, if cannot get used tyre inner tube, can use used condom..:stupid:
hmmm... good idea bro.... here's a bit of contribution, if lazy just get those rubber replacement washers for leaky taps. It's about the size of 10sen and has a hole in the middle. I think u can get a Ringgit for 4 in a package or something like that :rolleyes:
won't be able to fit as those replacement washers are kindda thick...
why waste a ringgit for 4 ...you may need atleast 9 of those for a door X the number of doors ..
tyre tuibs are cheaper and it's not so that thick ...get those used one will do bro ..maybe a ringgit could get you a lorry tuib and you can make more and more spacers ...
recycle ones would be cheaper :)
hi guys,tue after hari raya,i am going to ask my mechanic to replace the foam and the door clip on my door panels,will report back if it does help!cheers!
My left side passenger door seems to be squeaking. WIll replacing the door clips solve the problem?
bro ,
changing all the clips will cost you less than RM10 / door .
it's still worth a try - it even if the sounds did not go away .
the only problem is if the anchor hole for the clip on the
doorcard is broken / dislodged - then you need to get
creative with the 2 tonne epoxy :listen:
Hai santdagon
What is the solution?? that the noise appear against.. i got the same problem..
HAI mEGATNIZA
What meas need to get creative with the 2 tonne epoxy..
mine also got many squek sound...need to do it at KL....anyone know where is suitable place?
JMA;505887 said:
Hai santdagon
HAI mEGATNIZA
if the anchor hole for the clip on the doorcard is broken / dislodged ,
you need to modify / reattached the anchor hole with the
2 tonne epoxy .
crusher;508873 said:
Strangely, my squeaks has disappeared
after a car wash or heavy rain ??
that's normal ...then it will come back ...
i have learn to live with it ...LOL
parts & parcel of driving E36s ...
Come to think of it, it stopped after I drive back to Penang for CNY with my two children at the back. Still dont understand why it stopped.
hi all..
my e36 also having the same problem but its not squeaking, it just rattling sound.. i manage to fix it myself, open the panel, and finally found the sound came from the metal that hold the black plastic retainer..
frankly, im just using cable tie to fix it.. and it is simple work.. can diy.. =)
after this, need to replace all the door clips and manage to do it in this week if possible.. :smokin:
I also asked my mechanic to open all door panels/trunk and put new clips, after which 80% of the noises were eliminated. The only noises are from the front side passenger seat sometimes. I've just learned to live with it also.
Well I always have my stereo turned on in the car, so that way squeaks and noises are not a concern while driving on a bumpy/uneven road.
