AAM
- May 3, 2009
- 379
fabianyee;508999 said:before u do anything... What the RPM in 5th gear when the speedo is showing 100kph???
will check that tomorrow.
thanks fabian.
AAM;509262 said:had a test run yesterday.
update : running at 100 kph in 5th gear, the tachometer reading was 3,600 RPM.
thanks fabian.
thanks fabian.
AAM;509382 said:just for info : my E30 2.5L ( Auto ) - 100 kph at 3000 RPM ; E32 730iL ( Auto ) - 100 kph at 2200 RPM
never brave enough to test their top speeds - manage to touch 170 kph (before letting go the accel. pedal ) - can still go somemore ..........no complaint.
Zoggee;509764 said:try search youtube my name and browse thru my vids. You'll find something interesting. Was running stock M20B25 diff 4.10.
Sorry bro,the 4.10 is back onto my car. :smokin:Fireblade;509926 said:You still got the 4.10 diff? Am looking to replace mine cos its making noise.
AAM;509380 said:thanks fabian.
hope to meet you guys soon in one of those TT.
P/S : today manage to get hold 3.45 rear diff.
]AAM;510316 said:the 3.45 rear diff installed............will up date after test run.
p/s: gizmoz thanks for the stuff.![]()
gizmoz82;510382 said:]
ur welcome bro...
fabianyee;511472 said:looks like u need to get at least a 3.15 rear diff... or a 2.97...
or is your tachometer is showing the correct RPM or not?
try holding in 1 gear (maybe 3rd) and rev all the way even past 6,000rpm and wait for the needle to bounce off the revlimiter.. See at what RPM the rev cut cuts in... stock rev cut should be 6500rpm.. if it can go far beyond 6,500rpm.. then u may be using the incorrect instrument cluster...
