Zoggee
- Dec 4, 2004
- 6,170
In response to a thread http://www.bmwclubmalaysia.com/forums/showthread.php?t=27899&page=2maybe this would help.
kissmatt;506875 said:I start with question..
My 320 using 4.10 LSD..
Started to use last year..
But now I face a problem!!
The diff made loud noise..
I did replaced diff oil last month..
Found out lots of metal chipping..
Any clue what went wrong inside the diff?
M20 mod to 3.5??? U mean you're using the M30 3.5 engine???AAM;506953 said:just want to know - what is the most suitable rear differential ratio for E30 M20 mod to 3.5L ( M ) engine ?
mine have an issue - can only speed up to 160km/h when the tachometer reading touches the redline !!!
is it a rear dif. issue or something else ?
thanks.
fabianyee;506964 said:Loud noise? lots of metal chippings??? can be worn crown and pinion gears... it will whine like a pig... Can also be worn bearings... better to open it and see what's the condition of the gears.
What rear diff ratio are u using? auto or manual gearbox??
ur issue is definitely incompatible final drive ratio for the engine and gearbox.
r37720;506980 said:is it true difference ratio gives different acceleration performance?
Jules;506995 said:think of your bicycle which can change gears........
AAM;506974 said:fabian, thanks for your comment/inputs.
yes , mod to 3.5 L ( Manual ) - M30 3.5 engine, manual gearbox.
Rear diff ratio - dont know - will check it afterward.
Need help to address this issue n to optimise its performance:
1. What should be the ideal rear diff ratio/final drive ratio
2.Any advice on the size of the exhaust piping/silencer boxes
3.Any advice on the fuel pump change
P/s: Bought the ride, 2 doors wide body 2yrs ago on " as is where is basis " - no details on the mods done and have not done any major repairs/parts replacement, other than normal servicings. Suspension, i think was upgraded to stiffer sets.
thanks.
r37720;507105 said:for my current rides 2.5L - 6 cylinders motronics manual transmission, I am currentl using 3.73. Is this the best or can I optimised it further. Someone told me should go for 4.1
fabianyee;507236 said:stock M20 2.5 manual comes with 3.73 final drive... for your manual 3.5, u can probably use that or a lower ratio like a 3.45 or 3.25..
fabian, thanks a lot. will be posting on the progress of this issue. :top:
fabianyee;507236 said:4.10 on your M20 2.5 would enhance the acceleration... but engine RPM would be higher at the same speed once you swap from 3.73 to 4.10...
IIRC, for 3.73, your RPM should be about 2500rpm at 100kph. for 4.10, RPM would be 3,000rpm at 100kph...
TQVM fabianyee..
I should open up the diff sooner..
Hopefully my worn crown and pinion gears still OK..
If bearings, then straightaway i will replace them..
BTW, sometimes my diff feels disengage..
Even though i'm throttling, but i feel my tires has no force acts on it..
Like you push clutch while car is running..
Emm.. Hard to explain..
Any ideas, what went wrong?
Zoggee;507395 said:AAM if you got time,search google for BMW ETK. Lots of stuff to see from there.
Jules;507578 said:I am no guru but for a large capacity - u dun want ur engine to be revving faster than necessary....so AFAIK, the 4.10 were for the punny 1.8! My 323 uses a 3.25 and i think the E30 M3 as well.
Mind you, it also depends if auto or manual so a search on ETK to confirm is best.
AAM;507260 said:fabianyee;507236 said:stock M20 2.5 manual comes with 3.73 final drive... for your manual 3.5, u can probably use that or a lower ratio like a 3.45 or 3.25..
update on the issue : guess what......the metal tag ( screwed to rear diff. ) indicated the final drive ratio is 3.45! ........... so how come my ride cant run ?
so my conclusion........my answer is as good as anybody......... the tag was switch........but the rear diff.......
hopefully ,to get the guinine one soon......3.45 ratio.
AAM;508950 said:update on the issue : guess what......the metal tag ( screwed to rear diff. ) indicated the final drive ratio is 3.45! ........... so how come my ride cant run ?
