Bimshop Coding - F Series
Bimshop Singapore
Club Vendor
Hi guys,
Finally, we are rolling out the coding services for the F series.
We will be rolling out the coding services in stages, pending more coding options updates from our german side.
So for starters, we have coding services such as the speedo boot up with m-performance logo instead of bmw, brightness of ae lights, welcome lights, 1 touch 7 signal.....yes, 7 times....lol
So stay tuned for more updates.
Cheers!!!
Bimshop Coding
Auto Start/Stop Memory
on Bro Ng BMW F30 (Best viewed on fullscreen)
Basically, what we are doing is to enable your car to remember the last chosen setting for the engine start/stop instead of disabling it totally. So whatever mode you last chose prior to switching off your engine, be it Off or On, the car will remember and enable that mode the next time you start your engine.
https://www.facebook.com/BimshopSG/videos/10154902946609694/
We are pleased to announce that the coding for Aircon Circulation Memory Save is now also available for the F series.
Do feel free to contact us for an appt if you want to code yours
Bimshop Coding
Enable Idrive TPMS Monitoring for tyre pressure and temperature.
(Car must have existing original TPMS installed in order to enable this feature or else it will only read zero)
Bimshop Coding
Coding off Warm/Cold Monitoring for Rear Lights (Individually, ie reverse light, signal lights etc)
on Bro Gabriel Tan BMW F30
(Bro Gabriel installed aftermarket LED bulbs for his reverse and signal lights and found it to be flashing intermittently.
This is because the car is programmed to send electrical pulses to the electrical components to make sure its working, just that LED is very sensitive to pick that up and flash)
https://www.facebook.com/BimshopSG/videos/10156098766999694/
Similar threads
