err meetoo, as Lee36328 pointed out in the Bentley service manual.
- "A thermostat controls the flow of coolant into the radiator. When the engine is cold the thermostat is closed so coolant bypasses the radiator, recirculating from the engine directly back to the pump. When the engine reaches operating temperature, the thermostat opens and coolant circulates through the whole system including the radiator."
An engine will NOT heat up at the same rate regardless of the themostat. The proper thermostat will ensure engine heats up to operating temperature faster by the process described above. It prevents coolant from entering radiator so engine heats up faster. When it reaches operating temp or should I say temp of the themostat, it opens and allows coolant to flow through radiator and keeps engine at operating temp. Hence you are right in saying that we should always replace the thermostat with the correct temp spec.
The fan start-stop is NOT the work of the themostat but the work of the fan switch (temp sensor). When it gets above a certain temp it will kick in the fan to cool the system down to the set point when it turns itself on again.
The point I'm trying to make about themostats in malaysia is that the operating temp of an engine should be higher than 88 deg. (this is just my assumption, if I'm wrong I stand corrected). IF the operating temp is indeed higher than 88 deg. then the thermostat will have NO EFFECT AT ALL on the operating temp of your engine as it would be fully open at 88 deg. However, like I said above, if the engine's operating temp is lower than 88 deg. then I stand corrected and the thermostat will then have an impact on operating temp. I am assuming that with our hot weather the engine will operate at a higher temp than 88 deg. Can anyone confirm this?
