I had 2 occasion having problem opening my door. 1st time was travelled all the way from KL to PG island and stopped for dinner, after dinner central locking play trick on me not able to open door. Use key switch also cannot, ended up smashing the rear triangle window to unlock. Spent couple of hundred to find a replacement n fixed it at Chu Seng Penang and I can assure you , replacement window will definitely have air leaked !
2nd time, my battery ran flat at home, hv to use hard wire to insert between door n frame to unlock.
Now I am afraid of all these battery problem, so I fixed a black n red wiring from the battery pole under passenger seat going thru a hole to the trunk. Terminate each year and keep them separately. Just in case battery run flat, I can pop-up the trunk manually and connect both ends to either battery or "12v DC" adaptor.
