anaksarawak
Official Member
- Jan 20, 2007
- 4,154
bump for worshop who can retrofit ATF oil cooler
bmadzi65;771976 said:Wow..i think this is very practical to restore our gb performance longer....count me in bro anaksarawak if the is right.
anaksarawak;773607 said:Have a look at your radiator, if there a smaller radiator with hose connected to your gearbox then it is otherwise what she means the gearbox is connected to radiator via heat exchanger.
Alex5522;795676 said:AS are you talking about the hose no 4 & 5 from the dia ?
anaksarawak;795692 said:Yes, the idea is to connect a oil cooler between returning hose, not sure if its 4 or 5. With that the return ATF can be cooled via the radiator fan.
erica34;795789 said:i retrofitted oil cooler to my e46 328ci at bm world desa tun razak. i think it's ori/used from e36. all black and sits behind grille in front of radiator hence discrete - just the way i like. see post #10 by aidilj for the ATF cooler used.
polaris78;819070 said:Highly recommended for E46, GB can last longer. I had installed mine, temperature maintains always below 100c :top:
tropos_net;821190 said:wing did you manage to monitor the atf temp with the previous setup? (oil to water on e46)
just for comparison before and after mod.
