where did u heard or read about that? proven that it really happen? coz i already flush and change my ATFOriginally posted by vinson@Jun 21 2006, 08:19 PM
Flushlah of course. Its cleaner and removes deposits thoroughly. But due to the pressure of a flush, manny rubber parts that are weak and old, may also crack.
nope, m-speed USJ, the total bill was 900 for flushing, refilling back (esso), changing gasket & filter & labour (almost pengsan when i see the cost for changing ATF). 5000KM now so far so goodOriginally posted by scin@Jun 21 2006, 09:54 PM
Done it and lived to tell the tale ( so far la... 1000km )
Honestly, if you think about logically, it makes perfect sense to flush and change it on
a regular schedule. All the other side effects reported may just be arse luck or inproper flushing methods.
Mouse, you did at kanak kanak ah?
wow man, u r really a car lover, yeah that is also what i think if u dun flush it, change it more frequent and use the fluid inself as a flushOriginally posted by bibendum@Jun 22 2006, 09:03 AM
What I did is just to change the ATF, no flushing...
I intend to change it more often, maybe every 10k....cos mine is a recon unit... I also change my engine oil every 2-3k...... manual flushing rather than use the machine...
bro, when u goin again, we can meet there and TT opposite his shop (maybe c u there b4 also but dunno its u)Originally posted by aramis@Jun 22 2006, 08:51 AM
mouse, seems like you also frequent m-speed, me too !
bro, meet there one day and TT opposite his shop (maybe c u there b4 but dunno each other only)Originally posted by aramis@Jun 22 2006, 08:51 AM
Originally posted by Mouse+Jun 22 2006, 09:56 AM-->QUOTE (Mouse @ Jun 22 2006, 09:56 AM)
anyone know where is the dipstick for ATF (if there is any) if not then how to check not to overfill it?
that's what i read in some bmw uk mags...Originally posted by bibendum@Jun 22 2006, 09:03 AM
in mouse case, M-Speed does the flushing using up to more than 15 litres of gear oil b4 topping it up...i.e.from a dark sludge to a clear goldish gear oil...
points noted with thanx.....Originally posted by bmwcar@Jun 22 2006, 12:12 PM
Hmm...thread was started the right time for me....car is coming around to 50,000 miles (80,000km)....time for service and possibily ATF change...
Did some checking on ATF changes / Gearbox lifespan:-
1) Bimmer Magazine US - under buying used E39, which use the same engines and gearboxes as the 3 series mentioned that the gearbox lifespan is about 80,000 to 120,000 miles........
2) E46fanatics - the majority of the guys who responded to the 'steptronic good' thread have clocked more than 100,000 miles but most of them had done a ATF change/flush. But there were also guys whose box went kaboom when ATF changed but these guys first changed ATF at about 100,000 miles (161,000km)...so change before ATF 60,000 miles at latest.......
3) Word of mouth:-
a) Friend of my parents has had his E39 since 1997 - 126,000 miles and no issues with the car whatsoever.....but his cars ATF is changed every 50,000 miles.......
B) one forum guy has almost clocked 126,000 miles on his car and never changed his ATF...car runs well.....must be his bat out of hell driving style!
4) Other makes:-
a) V6 : alot of them require new gearboxes after 62,000 miles (100,000km) - cost recon about RM4K.....new RM15K....as much as a bmw!!!!
B) Toyota: altis : one guy in my office had his gearbox replaced at about 50,000km (31,000 miles)...cost RM8K - just after waranty expired....not sure how he drove the car but he appeared to take care of his car....will not park in the lower basement carparks as the lines on the ramps up and down wear out his absorbers!!!
My altis however - 2002 to 2005 - did 105,000 km including many spirited drives to genting and had no issues.....
Conclusion : luck of the draw for all car makes but changing ATF on bmw's before 62,000 miles will generally lead to a longer life....not sure how much longer....
to Flush or not to flush.....
Flush : if a gearbox can handle the internal pressure as the engine spins to 6000 rpm..... a flush should have no difference on the internals.... i hope...
Me.........car is due for service in about 4 weeks time......will decide by then, but if decide to change ATF, will do a flush.....think the workshop chosen has to have a proven track record on this.
