seenotype
- Feb 24, 2013
- 182
u can try search from mudah.com therechewhong;824036 said:Anyone 328i owner plan to sell their 18 inch 397 rim + rft ? Pls pm me, tuvm.
omnimech;824324 said:Honestly I think 275 may be a bit excessive.
Sounds like time for a wide body kit![]()
Mavik;824347 said:I don't think the F30 320i can clear the 275 width. Check your drivers door at the side next to your seat. They have a recommend tyre specs for the car there. For E90, max width is 255 recommended but I am running on 265 widths. 265 still ok but I have already rolled my fenders.
It will depend on the rims you are using, what are the rims offset and how wide those rims are. I am using 19" BBS CH-R with offsets of around 34+. 265 still doesn't rub the fender. The only lowering is the M-Sport suspension which is around 10mm lower compared to the stock suspension setup. If you use a more aggressive offset of around 23+, even with 255 or 245 widths, it will rub the fenders.xosix;824388 said:are you sure ??? because when i check on f30.. most of them are usig 285 30 20.. still didnt rolled the fender at all... its what they said la..
your 265 rub the fender over bump or full loaded person ? did you lower your car ?
Mavik;824412 said:It will depend on the rims you are using, what are the rims offset and how wide those rims are. I am using 19" BBS CH-R with offsets of around 34+. 265 still doesn't rub the fender. The only lowering is the M-Sport suspension which is around 10mm lower compared to the stock suspension setup. If you use a more aggressive offset of around 23+, even with 255 or 245 widths, it will rub the fenders.
You should DIYxosix;824418 said:the offsets i think 35, replica cv5 19"... i cant recall since i havent buy yet..thanks for the infos
and do you know any shop that i can install my pedal cover,break, footrest and kidney grill ???
Mavik;824435 said:You should DIYit is cheaper that way.
Otherwise you can check with Eurotuner who is the club vendor here. He is quite careful when it comes to installation. But again it depends on whether you are located in the Klang valley![]()
azlan87;824520 said:was thinking about changing my rims too... but then I saw one f30 in BMW Jln Tun Razak sprayed the ori/stock rims to matte black... looks quite nice... am thinking about doing the same too...
halidom;824538 said:i am also thinking about it!!! but my car is black. cant visualize yet. dont think its' nice. black n black
xosix;824544 said:nah, i dont think black and black nice.. maybe silver i guess.. check out the pic..
View attachment 30227View attachment 30227
halidom;824555 said:thats what i also thought!!! so got to keep the ori one!!!
what stick rim u having now ??xosix;824559 said:im gonna do the same thing, gonna change rims but i will keep my ori rims. incase of anything, i can just swap back.
u saw is 328 or 320??azlan87;824520 said:was thinking about changing my rims too... but then I saw one f30 in BMW Jln Tun Razak sprayed the ori/stock rims to matte black... looks quite nice... am thinking about doing the same too...
