Annoying soung when braking
lildevil
My car has this problem which is when i brake and its almost to stop this annoying sharp scratching sounds start coming out, its even worst after a long drive and alot of braking, already replaced the discs and pads a few times, skimmed but the sound just wont go away. Anyone here has a solution to this? Really hope to solve this problem. Thanks =)
is this your car i see many times at a workshop at Damansara Ara ?
My brakes have the 'eeee' sound when I stepped on them too. I have complained to AB when I sent for service but it still recurs once in a while. I'd like to know the root cause too.
U r too gentle with the car and the pads is not properly heat up... things get rusty and harden and thus start to "complain" (make noise!)
:D
Replaced disc rotor, shoes and skimmed... noise still ada... means u r looking into the wrong thing... did u seek 2nd work shop opinion? I suspect there are loose component at the wheel hub assembly and when u apply brake, the vibration causes the loose components to scream..
What ever it is, sounds like your pomen ran out of idea and its time to look for another workshop! before they reach their hands deeper into your pockets..
you mean kayu ara? If so then yes its my car, which else workshop do you guys think can solve this problem? mine does not sound just sometimes, it sounds every time!
