fabianyee
Founding Member
- Nov 25, 2004
- 8,860
- 38
EEEE30;469358 said:"Stroking a motor is simply changing the length of the stroke. If you make it longer the displacement increases and bigger inches usually equals more HP. If you have two motors that are equal except for bore and stroke, the one with the longer stroke will make more torque than the short stroke motor. The short stroke motor however will rev quicker because the slugs have less distance to travel. "
That basically explains what stroking means. But the main thing is that you have to be gentle with stroked motors and some people concern about reliability of the motor.
Reading you other posts, I figured you have a 318. If I were you, I would do the m20b25 swap into your e30 and be happy with it. m40 and m20 are worlds apart when it comes to performance.
M40 and M42 are aledi worlds apart, both being 1.8... 115hp and 140hp... lighter and more horsepower than the M20B20...
E30 325i would be faster than the E30 318is (with the M42) in a straight line. Stock vs Stock.
But the E30 318is would be more fun to chuck around in windy B-roads like ulu yam. Thanks to the lighter 4pot engine...
