ABS Problem
Sayed A Sani
All X5 Sifu,Got problem with my right wheel, when I turn to the right; sliding sound was observed; sound like the tire skidding on the road; and when I put on hard braking; the right tire went lock itself sound like the ABS does not functioning. Did the computer diagnose and found not faulty code...puzzle on what went wrong..plan to do right wheel ABS service...Any one have the same problem...with solution...???
Hi Sayed, have you checked the remaining thread on your tyres? Or maybe you can try swapping/rotating the tyros and see if the problem still persists.
All done...with new tires..sent to mechanic and observed ABS sensor problem..fix it but it came out again yesterday...
gratustk;582001 said:
great to hear that all is done :) had also smiliar problems with my X5
Solved everything when I completely change the front suspension with the normal coil spring suspension...
