about e32 brake master cylinder to e30
yim1986
there are a lot of ppl using e32 pump now, but they couldn't give me the confirmation whether the brake pump is plug and play, or need to do some modification to make the e30 front fluid lines into 1 then connect into the pump, and does it need the servo then only can plug it in?anyone knows the answer? urgently need the answer cause i will be fixing my brake system soon...thanks everyone.
yes, you will need another T for it cos the e30 has two front lines, 1 rear line..
if you need the T, i have a spare...cheap..
cheers..
cheers..
wow!!!thanks for fast reply!how much do you sell it?do you mind to show me some pictures of the T?and do i need to change the servo also?
Hi bro. the key here is the e32 servo. the servo is the one give u more power for the braking ( cuz it got double diaphragm).
so basically u need to fit the e32 master pump too.
the e30 stock master has three uotput. where else e32 got two only. so u need to find the "T" adaptor for the output which goes to front wheels. meaning to say u need to devide it into two which will go to each front wheels.
Am i right bro strider?
so so you mean i need to go machine shop to make one and fit it in?
or just buy one from pussy? dunno how much he will offer me...
just got a brembo front disk already wallet kong...
lolx
very sorry to hijack..
any idea how much the e32 servo and master pump is these days? ball park figure?
having the same problem with yim.. three outlet master pump thats hard to find.
very noob question i know but i want to learn.. if i use the T for the front lines would it have any affects on the braking power?
thanks guys..
no need to go to machine shop all. just buy from pussy. thts all.
the mod is a plug and play. one only extra thing u need is the T adaptor.
thanks guys..
the e32 servo itself will cost u 350-500. if u can manage to get a good unit. bit hard to get. how i know? recently i was chasing for this at some chop shop from klang to subag to puchong.
i was using the T adaptor. no complain.
so if i planned to use other model servo and pump, is the T works as well as the E32 master pump?
thanks for the reply guys... haiz.. headache solved. as for me i was wondering how to find a replacement three outlet master cylinder. my friend suggested i use one from a nissan cefiro A31 but its two outlet. everything else fits perfectly except this issue. now i know the solution. a darn T. haiz... oh well i learn another new thing thanks to you guys. thanks a lot for the info and good luck yim!! :)
if the master pump got 1 outlet only for the front, the T should work as same.
but i've not practicaly experience tht. better seek sifu's advice.
good luck ;)
aiya... i got it RM10 each used one s from chop shop.... come this friday's TT, i will bring it..
or call me on sat. meet in Puchong jaya side..
Today's price f the servo can reach RM400 for the set.
i used to have the 3 outlet type, super good.. i think i sold it to a forumer here...
the 3 outlet is one with a spare nut below the MC side.use it..
cheers..
cheers..
Rm10?! ok! will buy it from you if you willing to see it for me, haha!
hope to get your contact number because i might not free on saturday...
and where is your living area? best is too meet you there when i'm free...:top:
cheers..
.............:biggrin:
hEhE..i have the similar issue regarding the T adaptor. bro Pussy, by any chance do you still have a spare unit lying around ? do pm me if u do!
Cheers to yim1986 for bringing up this thread!
Cheerios
haha think i shall jump on the wagon as well.. if there are extra Ts count me in as well?? hehe..
wow!!!then i must garb it soonest possible!!! so that i wont be the last who cant get anything...lolx
just changed my brake disk and brake pad... cost me rm420, the brake disk is Brembo and the brake pad is a brand which starting with a J.... expensive for a mechanic...too bad no ayam brand, hehe...
if its not too much to ask can post up pics of your mod when its done for reference bro?
